2002 K member in Fox
89carb289
So I know the stock 2002 K member will fit in my fox with slight modifications. Will I be able to modify a tubular K member for a 2002 to make it work? I picked one up brand new for cheap. I already have stock fox length tubular a-arms that bolt to it.
You tubular K-member probably won't have to be modified to fit the fox. It has been my experience that most brands leave you enough room to bolt them right up. What brand did you get?
89carb289
It's a UPR Chromoly. Got if off another guy who sold his stang and never got to swap it in. Still brand new in the box. I did notice the holes are already elongated so I'm hoping it fits without too much trouble. It just scares me that they offer another K member that is specific to a Fox/Modular swap.
The ones designed for the swap have a slight forward offset on the motor mounts. Yours will be fine. Push it all the way forward when you do your install. You'll still want to square it up, but it will work fine.
89carb289
Thanks for the input. Takes some stress off my mind. I was reading up and someone did the same thing and said the motor just sat a little closer to the firewall but still fit. As for tranny crossmember I'll probably go with a stifflers as they work in the stock mounting location.
The K for my current project is an older D&D. It was a breeze to put in (and out and in and out). The Stifflers stuff is awesome. Brian is a very knowledgeable engineer and builds some of the best stuff on the market. If you need chassis stiffening, that is the way to go.
Any 4.6 K-member from a GT or cobra will work. You will have to elongate 2 bolts holes in the rear and trim about 1/2" of steel. I used a 03 Cobra k-member and team Z fox length Tube a-arms for 4V setup
bruce L
How do I know if the previous owner who did my 3v swap changed the k member I am new to this 86 fox body and I have no stock car to look at is there measurements from the firewall to know if I ammoved forward or not thanks
myers407
unless they moved the mounts on the K frame it has been changed. Look at the back two bolt holes and see if they have been cut out on a stock stile frame this is the common method of making it work.
