91 4v procharged cobra
quik660
Looked at the ECU in my car to be sure......I was a lil off..... The date on it is 2/17/96. It also said EEC-V
quik660
Awwwww heck..... Didn't pay attn to that. It wasn't the same as urs tho. Wanna say it started with a 2
quik660
Well last weekend I Thougt I busted a brake hose...... Turned out I split the rear brake line at the junction where the rubber brake hose attaches to the hard line. It makes a sharp 90* where it attaches..... Split it at the bend! Gonna have a braided line made and tear out the steel solid line.
4eyedcoupe
Nice coupe! I like that you stayed with the stock dash, something I would like to do with mine. How bad was it to wire in the aftermarket gauges?
quik660
I actually got the car with 4v already swapped in it......I imagine you could just add the needed sending units and they would work fine. I know there has been a coolant temp sensor added, and oil pressure.
1st gear......Pointless. 2nd gear......equally pointless! 3rd gear till about 55mph is a sideways blurr! Finally once it hooks, it'll ride!
Has a completely stock top end.... All the way to the TB. Bottom end has 9:1 JE dished forged pistons, mahle H-beam rods, 03-04 cobra forged crank...... And the best part..... Tesksid block. Procharger pullied to 10lbs...42lb injectors, 255lph FI pump with a T-Rex booster pump. Thinking bout swapping out the P1sc for a D1sc and going for 15lbs.
Really want some long tubes on it..... But I can't find any that I read about that fit properly. Y'all know of any?
JBA makes a nice mid-length with a 3" collector that has come WAY down in price. The Wicked Stangs Mustang Race car runs them and they would make a HUGE difference on your car. 6635S is the part for Stainless and 6635SJT if you are looking for a 1700 degree Ceramic Coating.
http://0053839.netsolhost.com/product_images/Exhaust Products/JBA Exhaust/6635S.jpg
http://0053839.netsolhost.com/product_images/Exhaust Products/JBA Exhaust/6635SJT.jpg
If you have any questions let me know.
Dustin
drfrazzy
Your set up is nearly identical to what I am installing in my car. Are you still up and around LOL to answer some questions
benstein IBC
Thought I'd share my hoopdie with u guys
benstein IBC
hey bro i had a question im doing the same conversion with the stock foxbody dashboard and steering column, was wondering how did you hook up the ignition on the column i set up all of the cobraharness but it doent match the plug on the coulmn.
