91' Coupe Terminator Swap
Discussion in '1979-1993 4.6L Conversion' started by Gearbox94, Jan 8, 2018.
  1. Gearbox94
    Gearbox94 Member
    22
    2
    13
    Hey guys, so i'm in the middle of my terminator swap and i ran into some problems yesterday after dropping the motor in. The problem i'm having is the steering shaft where it connects to the shaft coming out of the firewall is hitting the cylinder head on the corner, more specifically the bolt and nut.. I'll attach a picture so you can see whats going on but i never heard of anyone else having this problem.. Usually its the steering shaft hitting the header but i got tons of clearance there. The only work around i can see is maybe trying to get a lower profile bolt and nut and hope it clears but man it's close. I'm using a AJE k member with their motor mounts. Someone suggested to try K member spacers but after reading about them on Maximum Motorsports website it seems they would push the k member down which would in turn drop the motor down and further the clearance issue with the steering shaft bolt. I'm hoping someone has an idea i can try.. I don't know if its the motor not sitting in the car right or what but i'll attach a picture of the motor in the engine bay and a picture of the t56 shifter location maybe someone can tell me if the motor is off center.
  2. Xporter
    Xporter Member
    24
    9
    13
    I'm not sure either but maybe double check that your K Member is squared up, looking at the way the trans is sitting(closer to the drivers side) it almost looks like it should be more centered in the trans tunnel.
  3. Gearbox94
    Gearbox94 Member
    22
    2
    13
    Yeah that's what I was thinking. So i we.t out yesterday and messed around with it and ended up loosening the motor mounts and transmission mount and I was able to get the transmission to shift a little further to the other side and center up better in the trans tunnel. What do you think now? The k member that I used didn't have adjustment slots so I don't think I'll be able to adjust it any from how it bolted up.
    Bill likes this.
  4. 419forest
    419forest Well-Known Member
    195
    71
    58
    you can also drop the k-member 0.5 inch with spacers which will get you clear of your issue.
  5. cpearson1342
    282
    64
    58
    I had that problem, we used a low profile lock nut with a fine thread bolt
