93 Coupe/96 Cobra Project
5 lug conversion in progress. Hood and bumper installed.
Fox body wiring harness for the whole inside of the car, and then a 96 Cobra for the motor. On the fox side, it has a plug that goes to the water temp, oil pressure, and brake. Plugs into the same place as before on the hydroboost.
On the expansion tank, I just took the old fox body plug that went to the overflow tank and cut it spliced it into the expansion tank plug. That's for the low coolant light.
I haven't gotten the low oil light done yet.
The tach is an orange/white wire from the PCM that I just ran to the tach on the fox cluster.
The speedo comes a company that makes a box that converts the mechanical to the SN95 speedo. I can't remember what the company is called. I need to google search that soon.
