Greetings from Toronto Canada. This is a complete street car design to drive as good as stock and see some fun days at the drag strip. The car is not quite complete but it will be running soon. I have been working on it for a little over a year. The Mach motor and T56 should have been in by now but I came across a 04 cobra motor with 500 kms. I'm trying to get the funds to purchase it (sell mach, install cobra). This will allow the blower to actually work in its efficiency range. Current setup should be around 450 WHP and it will be pullied to 600 WHP if I get the cobra bottom end. Will be complete in March.
Heres the parts list
1993 LX Coupe Black on Black
2004 Mach 1 motor, 96 Cobra cams,
Mach 1 computer and wiring harness
Return style fuel system, Aeromotive 340 LPH Pump, Regulator, Fuel Rails, 39lb/hr injectors.
Stock Manifolds, Bassani X pipe with cats, Flowmaster mufflers and tails.
T-56,Triax shifter, Centerforce DFX clutch
Vortech JT pullied for 10.5 PSI (need a bottom end)
Adjustable QA1 Coilovers, 12" 175 lb front, 150 lb rear set up for street/drag
Team-Z Modular Swap k-member
URP Moly Rear Control arms.
SN95 Rear and brakes (fits 15" rims for the track)
M2300 Cobra Front Brakes
17X8 Rims that will be swapped Billet Specialties Street lites, I have 17X9.25 Rears, need fronts.
Here's a few sneak peaks, but you will have to wait a little for more.
Finishing up the suspension and brakes (adjusted really low and no e-brake cable)
Cool car has to have cool plates, and I'm a little vain
Motor When I got it (aviator motor convert to Mach 1)
Cam Install
Cam Install
