96 cobra motor witing to 92 foxbody question
Discussion in '???FREQUENTLY ASKED QUESTIONS???' started by benstein IBC, Jun 27, 2016.
  1. benstein IBC
    benstein IBC Active Member
    30
    1
    28
    im have a 92 foxbody and i currently installed a 96 cobra 4v motor and tranny,brakes fuel tank fuel lines and all engine harness l, but im stuck in the electrical part im trying to run the stock foxbody dashboard and dont know how or what to do to get it working with the o.g key and switches... any help will be greatly appreciated...
  2. Bill
    1,383
    240
    93
    Welcome to the party. You are in the right place. I'm not the right person to help you, but there are several wiring people on here that can. There are also some wiring diagrams that may answer your question already posted on here, so dig in and make yourself at home. Post up some pics when you get the chance.
  3. Zasada831
    Zasada831 Member
    12
    3
    13
    I'm also dealing with similar hurdles with my swap... Any info on this matter would be greatly appreciated!
    Ramiro Casanova and Bill like this.
  4. Bill
    1,383
    240
    93
    There is a ton of stuff on electrical hook up on here, as it is one of the most common issues. Welcome to the site. Dig in and read through all the different builds to see how many different ways people have done the same things you are trying to do. Make yourself at home
  5. cpearson1342
    282
    63
    58
    I've posted on a few different threads for useful electrical info, here is some of it again though. You guys will probably need more specific pinouts for your cars. Easiest thing to do is make a jumper harness that give power when it needs it to the pcm, there are a few that need constant power, power in run, etc. If you use the donor car's engine harness/pcm, you should be able to run just a few (less than 15) wires to make the jumper, depending on what type of stuff you're keeping.
  6. Saleen90-172
    Saleen90-172 Member
    21
    14
    13
    I used a 96 Cobra drivetrain in my 90 Gt and kept the fox dash and cluster.I used diagrams that members have posted on here and this specific shop manual (in the link below) and it saved me many headaches. I will say that one of the things Ford did was that they kept a lot of the same color code wires from 90 to 96 like the temperature,oil gauges etc so that part is pretty easy to figure out.I also didn't use a jumper harness,I just cut a new harness hole in the firewall behind the inner fender and ran the 96 wiring thru that and tied it into the fox dash wiring.I will get a few pictures in a day or so to show you how I ran the harness thru the firewall and tied some of the underhood wiring together if that will help you any.
    http://www.ebay.com/itm/1996-Ford-M...ash=item3f6acec4ae:g:vJ8AAOSwLs5XKqr1&vxp=mtr
  7. benstein IBC
    30
    1
    28
    koo man would really apreciate that, did you have to delete the pats? or did you find a way of bypassing it?
  8. benstein IBC
    30
    1
    28
    what have you done so far? im litteraly stuck on the wiring ?, dont know where to go from here lol
    people around me do the 03 motors not the 96_98 ones
  9. Saleen90-172
    Saleen90-172 Member
    21
    14
    13
    Ramiro Casanova likes this.
  10. Saleen90-172
    Saleen90-172 Member
    21
    14
    13
    Yes I had to buy a sct livewire box and have a pats delete tune put in it,I also deleted the rear 02 sensors in the tune.Here are some pics of how I did mine.
    I also took the fox red/blue solenoid wire and connected it to the black solenoid wire on the cobra harness so it would crank off the key.
    I did away with the relay under the seat on the fox and connected the green/red stripe fuel pump wire from the cobra harness to one of the old fox relay wires,although I will have to look to see which one.
    If you have any other questions just let me know but I will also say that you need to at least get the wiring diagram for the fox instrument cluster and the book I mentioned so you will know where to connect the red power wires and gauges to get the computer powered up.There is also a computer ground wire that needs to connected right by the kick panel area where the computer is.
    The way I did mine may not be the best way but so far it's been running good. 037.jpg 038.jpg 039.jpg 040.jpg 041.jpg
      File size:
      235.7 KB
      0
    Ramiro Casanova and Zasada831 like this.
  11. Saleen90-172
    Saleen90-172 Member
    21
    14
    13
    I am still in the process of making the wiring harness look a little neater (and since this picture I have moved the ccrm box into the inner fender area) but here is pretty much what it will look like when it's done.
    Zasada831 likes this.
  12. Zasada831
    Zasada831 Member
    12
    3
    13
    ive only done the mechanical things... I went and bought a wrecked 97 gt and have been using the wiring and parts off it... Basically swapping all of that stuff into mine...
    Bill likes this.
  13. benstein IBC
    30
    1
    28
    Thank you for the help
  14. Ramiro Casanova
    Ramiro Casanova New Member
    4
    1
    1
    Had this issue come up during a few discussions on this swap.
  15. 1fstcoupe
    1fstcoupe Member
    16
    2
    11
    This is very similar to what I am doing. Thanks for the diagrams
