brake question
bennyr5864
Hey everybody new to the site and in the process of a sohc carbureted swap into an 87 notchback , the car was carbureted when I bought it, I was wondering with a sohc cam if you need to switch to the maximum motorsports manual brake, hydroboost, or if my original setup will fit? Thanks for any input
FutureGuy said:
Your existing set up with a power brake booster probably won't fit. All SN95 Mustangs with Modular engines used the hydroboost because the engine is so wide there's no room for the vacuum booster. My advice is use the hydroboost.
