Fox Body or Cobra Pedal Assembly
Trakspeed
So my 85 is going from an automatic to a terminator motor with T56 trans, I have to change the pedal assembly out either way because of being an automatic. I have a manual set up from a fox body already can I use that or should I get one from an 03/04 cobra???
Up to you, but you will have to cut and modify the 03/04 pedal assembly to fit in the fox, I just used the brake pedal from the donor car (the 03) and cut it so the pedal was off to the left more so it would go onto the plunger.
