How to: Door Panels
Discussion in 'Interior Swap' started by myers407, Mar 12, 2013.
  1. myers407
    myers407 Well-Known Member Staff Member
    164
    76
    58
    I have tried several ways to do the mod to the SN door panels with some luck but also muxh work. I have now found a way to do it in about an hour with basic tools. I am going to put together a step by step of that process. Be advised that my numbers may not match yours as this will very with the way your dash was installed. Some adjustments will have to be made so take your time and if your unsure, get a set of junk panels for paratice. Good luck and if you have any questions feel free to ask.
    [​IMG]
    This is what we all have to start with, the problem is that the panel is taller in the back than in the front. This is what we will have to fix.
    Start by removing the staples from the back of the panel. This can be skipped if you plan to have the panel recovered.
    [​IMG]
    This is a shot of the panel with the skin pulled back. This is a chep way to do the panel as it can be streched back over the face later.
    [​IMG]
    In this shot I have mesured from the back of the panel to the point where my cut will end. In this method you will not seperate the top half of the panel from the bottom. You will be left with a hinge to fold the top down. It will be seen soon. Remeber that my mesurements will not be the same as yours but should be close. This one will likly not change.
    [​IMG]
    This is the back end of the cut, or the higth of the new panel. This is the one that I would think would be different.
    [​IMG]
    Connect the lines to get the cut line.
    [​IMG]
    The second line follows the contour of the top edge of the panel. This is the area where it rolls down.
    [​IMG]
    [​IMG]
    The lines will intersect at the front of the panel near the slot for the door cups tab. This is where the cut will end.
    [​IMG]
    This is what I have found to cut with. I have tried it all. But thsi seems to work the best. They can be found at any hardware store.
    [​IMG]
    [​IMG]
    Take your time to make the cuts. You have to be carful and don't let your tool get away form you. The bits of plastic that fly at you will be very hot so where glasses and a long shirt. You should end up with something like this.
    [​IMG]
    The top piece can them be foled down to look like this.
    [​IMG]
    Now you will have to take a heat gun and warm up the area marked and relax the plastic.
    [​IMG]
    [​IMG]
    Now this is what you should have!!
    [​IMG]
    With the top pulled down there is small piece that will need to be cut off. This is the back of the top end of the panel.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    After some trimming of the piece that was cut out it can be gled back in later in the process.
    [​IMG]
    [​IMG]
    Now you will need to remove a small rib from the inside of the panel. It is marked in this shot with the black arrow.
    [​IMG]
    [​IMG]
    You then have to cut the corner of the panel and heat the area to pull it in. This has to be done to keep the panel lined up after gluing it back together.
    [​IMG]
    [​IMG]
    This picture shows a small tab that has to be cut off after the panel has been reshaped.
    [​IMG]
    You will need to trim the front of the panel to get it to fit between the dash and the door.
    [​IMG]
    Next you can tape the panel up with a good high end duck tape. This is when the piece that you trimed up early on is put back.
    [​IMG]
    [​IMG]
    With this done you can now use a good high end plastic body filler. It will hold the panel together quite well.
    [​IMG]
    [​IMG]
    Rember that bondo gets hot and shinks. It may take time to get it built up.
    If you have taken your time and are carful this is what you should have.
    [​IMG]
    [​IMG]
    Be sure to make sure that the panel lines up with the dash, attiton to detal.
    [​IMG]
    egbertnr, 85fox2v and ModFoxMustangs like this.
  2. Zvines1290
    Zvines1290 Active Member
    68
    9
    28
    NICE write up!!! whenever i finally get started on mine i wanna definently try these!!!
  3. chris.c
    chris.c Member
    7
    0
    11
    I will have to follow this guide if/when I decide to do door panels, good tech! How are you connecting them to the inner structure of the door as I know the fox uses push pins and the sn95 uses slide steps. Also what about the latch pull?
  4. Speedtospare
    Speedtospare Well-Known Member
    717
    148
    73
    Very nice write up.
  5. whiteponygt
    whiteponygt Well-Known Member
    526
    138
    73
    how are you attaching the bottom of the door panel to the door and did you have to remove the L shaped hooks that slide the panel into the door on an sn95
  6. myers407
    164
    76
    58
    Sorry it took so long to reply. I did remove the L shaped SN catches. I made a small L bracket and put it on the door and put two small screws through the bottom of the door panel where they are not seen. As for the door pulls I have cut them out of the doner car and welded them in place on the fox door.
  7. lescok
    lescok Member
    15
    1
    13
    Nice work.
  8. WiserThanNormal
    WiserThanNormal Member
    6
    2
    13
    Probably going to recommend this to my buddy.. awesome write up. Thanks a lot
  9. vettn71
    vettn71 Active Member
    97
    20
    28
    So, what’s the deal with Photobucket? I’m getting an error messsage where each figure should be. Going to Photobucket gives a page wanting $33/month to view the figures.
    Jim
  10. Cobraboy03
    Cobraboy03 Member
    6
    1
    13
    wish I could see the pictures but from reading it doesn't sound too bad LOL
  11. Bill
    1,400
    240
    93
    It really isn't too bad. I would recommend that you grab a beater panel from the junk yard to practice on. About half way through, you'll figure it out and move on.
