Hydroboost Final Connection
Discussion in 'Brakes' started by 419forest, Apr 10, 2014.
  1. 419forest
    419forest Well-Known Member
    189
    64
    58
    I am going to tie the two ports on the distribution block to the bottom of the master cylinder for the hydroboost module.
    There is a third brake line that comes from the driver's side front brake caliper. How do I tie this into the hydroboost setup? I only see two outlet ports on the bottom.
    Pics are below.
    Thanks,
    Craig
    ModFoxMustangs likes this.
  2. bjmayberry2
    bjmayberry2 Member
    21
    4
    13
    Try this link http://dave78chieftain.zxq.net/hydroboost_brakes.html Maybe it will help
    419forest likes this.
  3. 419forest
    189
    64
    58
    thanks. I found another source which shows that I will need to tie the two front lines together by using a "tee"
  4. Svt Fox
    Svt Fox Well-Known Member Staff Member
    801
    154
    73
    I just used the modular distribution block. No tees were needed.
  5. 99 big red
    99 big red Member
    29
    9
    23
    Any updates pictures regarding this?
    Sent from my iPhone using Tapatalk
  6. Svt Fox
    801
    154
    73
    Update? Car has been drivable for a year now.
    It's not pretty (lines) as I used the fox lines and re-bent them as needed.
    [​IMG]
    [​IMG]
  7. 99 big red
    99 big red Member
    29
    9
    23
    Function beats looks in my opinion. Lol good deal. So you used fox lines and new edge block? Correct?
  8. Svt Fox
    801
    154
    73
    I grabbed the line fittings and block out of a 96 GT.
  9. 99 big red
    99 big red Member
    29
    9
    23
    Cool I've seen the tee method but this looks better I think
  10. Svt Fox
    801
    154
    73
    Especially if you take the time to bend the lines, correctly. I regret not making it look nicer.
  11. 99 big red
    99 big red Member
    29
    9
    23
    No biggy it's like a really hot girl with a big bush!! Can't see it so it won't hurt you!! Lol
  12. 419forest
    189
    64
    58
    thanks for posting the pics. Craig
  13. Svt Fox
    801
    154
    73
    You're welcome.
  14. bc474
    bc474 Member Donator
    20
    9
    13
    What is the point of the "coil" I always see in brake lines? It is required for something or will this work? P2181809.jpg
  15. Bill
    1,346
    238
    93
    The coil/bend allows flexibility in the line. On the Fox chassis, there is a hinge effect at the firewall, making the distance between the bottom connection on the booster (mounted to the firewall) and the distribution block/pressure regulator (mounted to the front subframe assembly) change under cornering, acceleration, and braking.
  16. Just Headers
    Just Headers Member
    11
    1
    13
    Always wondered why they were coiled...
  17. RussellJew
    RussellJew New Member
    2
    0
    1
    I'm in the process of swapping the front end, rear end and hydroboost system off a 98GT donor car to my 89 Fox. I have done a little research and have ran across people saying not to use the proportioning valve off the donor car. It looks as if a couple of guys on here have. If you have, hows it worked for you thus far
  18. Bill
    1,346
    238
    93
    The proportioning valve in combination with the rest of the braking system you are installing will give you factory feel brake performance.
  19. benstein IBC
    benstein IBC Member
    28
    1
    23
    I used the poportioning valve from a 96 gt but one of the fittings leaks any suggestions on how to fix it?
  20. Bill
    1,346
    238
    93
    Typically, leaks from fittings are caused by damaged flare or seat. If it is the flare, and as long as it isn't cracked, you might be able to fix is with a flaring jig. If not, you'll probably need to replace a section of the line. If it is the seat, you may end up replacing the valve. I have had some success with Teflon tape, but use it sparingly.
