Interior Insulation
Discussion in 'Interior Swap' started by cpearson1342, Oct 7, 2015.
  1. cpearson1342
    271
    60
    58
    This isn't exactly a interior swap question, but I will be swapping mach 1 seats into my car after I do this. My question is that I want to go with some aftermarket heat/sound insulation and wanted to know if you guys have used any and which you think is best. I'd like some comments from people who have actually used the products as it's pretty difficult to decide just from looking online at them.
    ModFoxMustangs likes this.
  2. Bill
    1,331
    235
    93
    I am interested in this as well.
  3. bigjohnsondohc
    bigjohnsondohc Active Member
    67
    23
    28
    This is the only picture I have but I used 3m material. They are 1x squares with a sticky back, the price wasnt really bad either and theres realy no cutting that you have to do unless its small areas.
    [​IMG]
  4. cpearson1342
    271
    60
    58
    How well does it work, or you haven't tested it yet? I have an o/r x pipe with straight through mufflers and probably about to go to longtubes so I need some decent insulation. If I was just looking for sound it would be easier, but I need heat/cold too
  5. bigjohnsondohc
    67
    23
    28
    I havent tested it yet, in the process of a motor swap.
  6. Jjnjd03
    Jjnjd03 Member
    15
    4
    13
    I do car ajdio for a living and we have found the stinger sound deadning is about the best out there
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  7. cpearson1342
    271
    60
    58
    Still haven't committed to anything yet, any other suggestions?
  8. cpearson1342
    271
    60
    58
    So we went with Raammat by Raamaudio, haven't gotten to see if it works yet because the car isn't running, but I'll let everyone know how it is after we get everything running. Seems like very good quality, and also seems like once you stick it down it's not coming back up 20160109_181858.jpg
    Bill likes this.
  9. azsnake
    azsnake Member
    12
    4
    13
    For anybody who may be looking for an option in the future DEI makes an AWESOME thermal shielding
    It's a bit pricey at $92.00 a 30"x40" mat, but it's probably one of the best available.
  10. vettn71
    vettn71 Active Member
    96
    20
    28
    Bill,
    I did a lot of research on this. Most sites will say se RamMat, FatMat or something similar. What I found is that three parts are required. The butyl rubber-based products is to dampen resonance, not so much to sound proof. I've done two Mustangs where I covered every square inch of the interior, door, trunk and wheel well. Almost no difference. It damps panel vibration and not 25 to 50% coverage is needed. I used Noico and like the way it lays down
    The second part is closed cell foam. This is very dense and heavy. This is what muffles sound. The last layer is thermal insulation. I used ThermalTec. It was $23 a roll at Amazon. The roll s maybe 6x4. It took two rolls for the floor. I need one more roll for the roof.
    I thought I saved the websites I found the information from, but I didn't. Google auto sound proofing. You'll have to wade through all the sites (some from "pro" shops that only recommend the butyl rubber products. You will eventually find the sites I did
    Hope this helps
    Jim
    Bill likes this.
