proportioning valve
So if I'm understanding correctly you guys are using the proportioning valve off the donor which in my case would be my 96. This is where I'm confused since the brake lines off my 83 don't match the 96 proportioning valve are you guys cutting the ends off installing the the end caps off the donor and then reflaring them? How does the firewall plate look? lined it up using the hydroboost still need to pop rivet it in.
Sent from my LG-H910 using Tapatalk
The hydroboost should match up to the propotioning valve with the lines that came off of it. The old style uses standard thread on the line nuts, while the new stuff uses metric so you can either use new with new or make custom lines.
Ok so I took all the lines of the donor car should I just use those and then use a T for the fronts?
Or use fox lines and bend them yourself. I bought m12 and m10 to some standard size adapters from advance auto parts and made my own
