JCTermiFox8704
Ok, first post on this forum. I have had my 87 GT since i was 15 (my first car) and i have finally decided 18 years later to do a much needed overhaul. I purchased a wrecked 04 cobra coupe with a 2.8 Kenne Bell, UPR K member, coilovers, and a bunch or motor work (which i can post ab later).
I will be working on this project starting next month and want to order wheels when i switch over to 5 lug.
For those of you out there that have done the IRS swap on a fox, what are you running wheel and tire wise? Need to make sure they sit pretty flush and clear the 04 cobra brakes. The IRS i have has MM coilovers front and rear. I am also going to run the Cobra A arms, brakes, spindles up front.
I was thinking ab the Weld Forged RTS wheels. The rear 17x9 with a 48MM offset and then maybe a 17x8 front with a ?? offset. I have no clue what to run offset wise in the front or even wheel size wise? How ab tires? What would you recommend tire size wise? 275/40/17 reat and 245/45/17 front?
The car will be a car show, weekend, nice day driver...So i dont need a set up that is practical for everyday driving, just one that works.
Thanks in advance for any help! Ill be sure to post up some pics and start a build thread!
