2000 cobra injector rails and throttle bracket
coryjones
I am looking for fuel rails for the 2000 cobra intake does anyone know if the standard 4.6 rails are the same? I am also looking for the throttle cable and bracket is there a after market version of this bracket?
Almost everything on the top of the 2000 Cobra is unique to the 2000 Cobra. Are you sure it isn't a 99/01?
I'm pretty sure the spacing is different on the 2V verses 4V factory lines.
I've seen the go over 600, but that is a function of pressure and setup. Aftermarket rails are always a good idea if you are going to spend money on big HP. If you looking for 500 or less and aren't worried about what it looks like, stick with the factory stuff. You can always upgrade later.
coryjones
I think i would rather go with something that has a cross over front and rear and i don't have to replace it down the road.
