List your parts you swapped over to your fox
Just curious on what parts everyone has swapped over? Good for people asking questions on how to make it work.
I have swapped in
04 Mach 4.6 4V Motor
04 Cobra T-56
95 SN95 Rear End (lets me run 15" rear rims)
04 Cobra M2300 front brakes
04 Mach 1 Hydroboost (using fox peddles)
04 Mach 1 Steering rack using MM SN95 Steering shaft
Team-Z Modular Swap K-member
QA1 Coilovers Front, UPR Coulovers Rear
QA1 Adjustable shocks and struts
Team-Z Caster Camber plates
RJM Wiring Harness
UPR Upper and Lower control Arms
vabeachsand
Hell yea I street Race!
I purchased a Maximum Motorsports grip box:
  • MM K-member (with 2-point brace)
  • MM Front Control Arms
  • MM Torque-arm
  • MM Panhard Bar
  • MM XL Series Full-length Subframe Connectors
  • MM Coil-over Conversion Kits, Front and Rear
  • Coil-over springs
  • MM Caster/Camber Plates
  • MM Aluminum Rear Lower Control Arms
  • Bilstein HD series struts
  • Bilstein HD series shocks
  • MM Adjustable Rear Swaybar
  • MM Aluminum Steering rack Bushings
  • MM Solid Steering Shaft
  • MM Bumpsteer Kit (adjustable outer tie-rod ends)
  • MM Strut Tower Brace
  • MM Front Swaybar Relocation Kit
  • Front Swaybar Bushings
  • Front Swaybar End Links
So far everything above is bolted up with the excecption of the torque arm, k member, panhard bar, and rear swaybar.
I have converted the car to a hydroboost setup, and installed cobra rotors and calipers both front and rear. The car currently has a 4cyl, but I have rebuilt the 8.8 and installed it in place of the 7.5. I replaced the rear cover with one from a Mark 8.
I have a mark 8 block and B heads that will be installed once I get it fully assembled. I went w/ Manly H beam rods, Kellog Crank, and Diamond dished pistons w/ valve reliefs. Compression is 9:51
Wreckedj30
My 89 gt modified convertible has
93 Lincoln mark Viii 4.6 dohc
03 mustang Gt tr-3650 5 speed
98 mark Viii intake manifold, imrc delete and cop valve covers
98 mark Viii fuel rail modified return less
01 mustang gt modified wiring harness & ecu
01 Mustang Gt fuel tank modified
01 Mustang brake system, hydra boost, abs, front calipers
01 Cobra irs 3.27 with cobra driveshaft, rear calipers and blistien shocks
Qa1 front kmember 4.6l
93 quick ratio rack n pinion
89 front lca's with 96+ ball joints
96 mustang spindles
89 4cyl front springs
17" bullet rims 245/45/17 falkens
Corbeau front seats
Custom rear battery box
Griffin radiator
Sct prp with e85 tune
Needs to be installed
96 black interior; rear seats, dash, door panels, steering column & bearing assembly.
Double battery solenoid setup
Irs exhaust
I have swapped in
04 Aviator 4.6 4V Motor with a Mach 1 intake
04 Cobra T-56
RJM Wiring Harness
Edited for correctness.
Actually, it will need to be edited again. Just waiting on Gaskets and time to finish the Eaton swap. Lideo at alternate will be tuning the car. 3 weeks until spring here!
Oh, I was under the impression that the eaton swap was already done.
If you don't mind saying, how much did the parts for the whole eaton swap run you?
Not complete yet. Started the Swap should be complete in 2-3 weeks. Grinding the knock sensor bumps is the worst part. When the snow is gone I have to drive it 6 hours from Toronto to Michigan to get it tuned. Debating to drive it or trailer it.
I picked up the entire swap for $2400.00. I am putting all new gaskets in the car and that costing about 75. I was missing the intercooler bolts and that ran about 20 bucks. Figure about $2500 (Canadian) all together. It came with a 2.8 pulley but that is too much boost (14 psi) I'm going to put a 3.4 pulley which is 10 PSI and make about 450 whp.
89 Coupe
Swapped in parts:
  • 4.6 DOHC Mark VIII 93 model
  • 96-98 cobra intake
  • bassani mid lenght headers with BBK X-pipe
  • 03-04 BBK CAI fabbed to fit
  • 96 stock K-member with fox A-arms
  • Hydroboost barke setup with SN95 pedals
  • SN95 dash, column, and console
  • 96 cobra wiring throughout whole car
  • 01-04 tremec 3650
  • 99-04 radiator cooling fan
Original fox parts used:
  • Fox radiator
  • Fox gas tank and lines
  • Stock steering rack
David
86 hatch
03 mach 1 4.6 donor car...complete drivetrain including a/c, fuel tank and lines
03 mach 1 k member control arms, hydraboost, rack and pinion
03 mach 1 complete interior...including door panels....minus hatch area
03 cobra brakes...front and back...struts and shocks
03 cobra irs
MM caster camber plates
86 hatch
03 cobra irs
Did buy the car built or did you build it?
dewayne
91 coupe 5.0 5speed car
Built my self
98 mark 8 dohc 4.6
96-98 cobra intake, imrc deleted
All emissions,agr,cats and secondary o2s removed
Ron francis mk97 wiring kit
Pacesetter longtube headers some modifications needed
4r70w trans transgo stage two shift kit
Upr modular/ fox kmember & a arms front coil overs upr caster camber plates
97 gt hydroboost,..fox pedals
98 mustang gt spindles and brakes..... 97 gt 8.8 with disk brakes 410 gears
svo e brake cables
Wild rides battle box reinforcement kit
Mid length frame connectors...for now....
mega bite jr lower control arms ...03,04 mach 1 wheels.
98 mark 8 radiator & fan.
98 mustang gt....a/c lines, condensor, dryer tied to fox a/c box....tig welded the rite connections on it
stock fox gauges ....170mph saleen speedo out of a 87 saleen#214
You guys should include what engine and body harnesses you're using. Thanks for the info.
My current project's body harness came out of a 2000 GT convertible. The rest of the harness and engine all came from the 99 Cobra donor.
My project doesnt fit in here but its a teksid in a fox. So far
Dude...your project fits perfectly here. You're starting with a bare Teksid. Most of these guys will never start with a bare block. I love the concept of the stroker kit and 14:1 on E85. That thing is gonna scream
I would love to build a 4.6, I put together plenty of 302 but for some reason I feel there's a learning curve. If you screw up a push rod your out a grand if you screw up a 4.6 you out about 3 times that.I have the Sean hyland book that tells a few combo they used to make decent power but no machine shops local will touch a mod motor .
hipoman
My mashinest is willing to mess with. Theres another shop across the river that does to. All my motors but one that i've built have been push rod. I'm not afraid to try these mod motors & see how well i can do it. You shouldn't be intimidated either. Read, research and get with other guys in the know. Thats what ive done in the past & what i'm doing now. I may mess up somwher but i'll learn. Getting there is 1/2 the fun & when u hear it fire up the first time, drive & work out the bugs you'll smile. HAVE FUN!
