i have two questions first off the swap is a lincoln swap in a fox. the lincoln motor was COP i used the 97 gt harness everything plugged in nicely but when i got to the coolant crossover tube i only had one sensor wheres others ive looked at is apposta have two sensors. under the intake manifold there is two sensors that run together and there is a brown round plug that doesnt match anything on the harness do i need to wire that to one side of the coolant sensor? I hope i made that clear enough. Question #2 I swapped over the complete body harness into my fox how did everyone wire in the doors did you use the new door harness or pinout the out and new harnesses. Let me know if i need to clearfiy anything or post pics
