5.4 2v swap
Discussion in '1979-1993 5.4L Conversion' started by Khris, Jul 16, 2017.
  1. Khris
    Khris Member
    10
    0
    11
    I'm doing a 2v turbo swap on a 87 mustang . I'm wanting to use factory wiring out of 99-04 gt so I can tune it with sct.. not worried about the stock gauge cluster working as I'll be doing gauges eventually.. I did few searches and didn't seem to find anything.. what harness's from he gt do I need ? I need the obd2 port to work also ... thanks in advance . Sorry if it's been ask before I just wanna make sure before I go buying a harness I don't need..
  2. Khris
    Khris Member
    10
    0
    11
    I was reading a thread that said there 8 wires you power/ground to the ecu and u can run it that way..
  3. Y2K GT
    Y2K GT Member
    13
    1
    13
    just curious which way you went with this.... I'm doing a 5.4 2v swap in my fox too. Don't have the dash harness yet, just the engine harnesses. Did you use the fox dash? I would like to use the fox dash and kinda retrofit the 99+ gauges or if need be autometer.
