96 4v won’t fit in mod swap k member
Discussion in 'Modular Conversion Discussion' started by 91bimini_coupe, Jan 23, 2018.
  1. 91bimini_coupe
    91bimini_coupe Member
    5
    1
    13
    been helping a buddy with his 86’ 4v swap and can’t seem to get the motor to drop into the k-member. Seems as though the oil pan is hitting the k-member. Do we need to swap oil pans for correct fit up or are we missing something. This is a first time swap for both of us so any info helps. Thanks
  2. Gearbox94
    Gearbox94 Member
    22
    2
    13
    What k member are you using? I just dropped a terminator motor in my 91 with an AJE k member and it cleared the oil pan just fine.
    Sent from my SM-G928V using Tapatalk
  3. 91bimini_coupe
    5
    1
    13
    Maximum motor sports. When you dropped yours in did you leave the kmember a little loose for play and wiggle room or did you snug it up before dropping it in?
