96 cobra wiring and fast blink
Discussion in 'Electrical Wiring' started by chris.c, Sep 15, 2013.
  1. chris.c
    chris.c Member
    7
    0
    11
    If I use a 96 cobra complete wiring harness on my 93 fox I will get fast blink because of only one rear brake/blinker. How is this typically resolved? Would it be possible to eliminate this by converting both front bulbs (inner and outer marker lights) to blinkers?
  2. ponyboy89lx
    ponyboy89lx Well-Known Member Staff Member
    846
    152
    73
    I have both my front lights wired to turns and it still blinks fast, but only with the signal on, I can turn my hazards on and it will blink normal. I pondered on this forever and could not get it to do right so I just let it be for the time being. The problem is that SN95 has multiple brake and signal sockets for the rear versus the fox body having one brake socket only and one turn signal socket only. When I first installed my harness I had the turn signal and brake light would light up when I hit the brakes and signal. I simply just left one of the bulbs out on each side in the rear, and of course that's why I have the fast blink. If you get it figured out do tell how you done it.
  3. chris.c
    chris.c Member
    7
    0
    11
    Haven't gotten that far yet, but it came to mind. I'll update when I figure out what to do. Still pretty early in the swap, working on gutting the cobra right now.
  4. benstein IBC
    benstein IBC Active Member
    33
    1
    28
    how did you get your turn sig als to work on the swap?
    ive heard that i need to switchy turn signal lever? that true?
