Alright guys here it goes, im wanting to do a swap 96 Mark VIII into a 91 fox coupe. The Lincoln is 100% complete runs and drives coupe is nothing but a roller right now. What im needing is some help/direction on what i need to know before i tackle this project. ill give a list of stuff i have and a kinda game plan... Car is going to be a DD nothing fancy other than a CAI and gears for the time being.
From the little ive seen you do need a mod K member which i have, I have the stock K member out of my 03 cobra, complete with A arms etc. i read that you have to do a little trimming to get these to fit which isnt a problem cuz im a decent welder/fabricator.
Where im going to have the most problems is wiring.... i HATE wiring, but i think im competent enough to do the swap (i hope) how much of the interior harness will i need? also can i use a Fox gauge cluster? i dont mind running mech. gauges if needed.
Brakes im planning on running a manual setup, its just gonna be a DD so no real need for a hydro boost, that is unless its a super easy swap in which case id be willing to try it out.
Fuel system i have no idea on... can i use the setup in the Lincoln? if not what is a cheap/easy system to use?
I will be using the 4R70W and can modify a trans cross member.
Any other tips would help out ALOT
Thanks
Jake
Thanks
Jake
