Fox fuel pump and wiring conversion
I plan on using my stock fox fuel tank with an upgraded 255lph pump. I plan on using all 1996 cobra wiring with 4.6 4V crate motor. Will the 96 cobra fuel pump wiring work on that pump? Besides the CCRM, is there any other relay that controls the fuel pump?
Should work just fine. It seems that unlike the mach wiring, there is no fuel pump controller on the 96 and is only controlled by the CCRM
I converted to a return style setup but mine come on with ignition with a relay just like above. No issues
