How Do I Adjust the Trunk Lid on a Foxbody Coupe
Discussion in 'Exterior' started by vettn71, Oct 3, 2016.
  1. vettn71
    vettn71 Active Member
    97
    20
    28
    image.jpeg Ive got waaaay too much time in this trunk lid, but I can't find how to adjust it from side-to-side. It adjusts front-to-back fine. As you can see, it is over to the left pretty hard. It is away from the right side, also. The FSM for the body makes no mention of the trunk lid or the hood, for that matter. Is there any way to center the trunk lid?
    Any help would be appreciated
    Jim
  2. vettn71
    97
    20
    28
    I tried to adjust this using the bolts on the hinges. It will go front to back, but not side to side. As it is, the left side almost overlaps the body, while there's gobs of room on the right side. Oddly, the gaps are fairly even on both sides
    Jim
  3. Paul
    Paul ModFoxHatch
    11
    1
    13
    Possibly a warped trunk lid?
  4. vettn71
    97
    20
    28
    I pulled the trunk lid yesterday. It's funny. I can get the trunk lid to adjust when I only tighten the left side bolts, but when I tighten the right side, I moves it over to the left. The hinges have a partial twist on them. I assume this is normal. I was considering putting a pipe over the end and bending them a bit. My concern is putting a crimp in them, which would basically leave me screwed, blued and tattooed. Has anyone done this? Any issues?
    TIA
    Jim
