Need a little help here.
Could you guys help rate the manual trans by power reliability and performance.
Technically, the T5 doesn't go behind the 4.6
I know the T5 is rated around 400 lbs stock. ( I think)
Where does the T56 and 3650 come in at?
I was planning on using the T5 for now, but I found a 3650 on Craigslist for $100 that grinds going into 3rd at high rpm, (sounds like synchro). ...... T5 parts are cheap, I'm new to the other trannys.
How do all of them fit into the fox?
