My 1986 Mod Fox Build (Mark VIII 4v)
cdog02mustgt
HoAdD8304QyIQIuUCEFIK6WiecNdd9_loUvmCceVGxI=s233-p-no
t8O-waiUBeEF-i6hKs9ewfqlCrh6oTf9P3rjTEzSUyQ=s233-p-no
my modified trans cross member and clutch/brake pedal
shcctx
I originally started the build buying this LX that was pretty much ready for the crusher. The car was a 4cl car that had been sitting in a field for about 6 years. Everything was pretty much garbage. All the plastics were beat form the New Mexico sun.
Here is the progress in pics
Right away I started taking the car apart.
Found a power plant in the form of a 351w from a mid 80's van
Got the car running a driving with the 351w c6 and stock 4cyl rear on nasty old tires
Finished filling the holes in the engine bay and cleaning up some wires....Time for some engine bay paint.
While working on the body
Time for some paint
All put back together with the 87+ quarter windows
Time for a some interior
Ditched the C6 for an AOD put in a small cam, and put in a new carb.
Did a Mustang 5 lug swap and put in an 8.8. Also picked up some GT wheels to roll the car around. Also replaced the windshild.
As it sits now. I decided to do the swap because I am having a few issues with the AOD and the motor has not been the most reliable. I Ended up picking up a 1998 lincoln mark viii at an auction and thought it would be a great donor car for a swap. The car had 123k miles and ran great.
I just started pulling parts off of it for the swap.
Here it sits as of today. More pics to follow as progress keeps moving.
Keep us posted
cdog02mustgt
Little update. Put in the x pipe and exhaust is all bolted in. I fixed the steering shaft issue. When pulling out the old motor it got hung up on the steering shaft and bent it. I replaced that as well.
I am not having problems with the brakes. I am thinking the master is dead. One on order and hoping that is the issue.
cdog02mustgt
A couple of updates, Got the intake tube on, installed a junkyard find flowmaster cat back, worked on some more wiring clean up, cut a half a coil off the front springs, and made a mach 1 lip I had laying around work on the front. So far I have put a few miles on the car driving it around the block a few times. Running pretty good considering I still have not tuned it.
cdog02mustgt
Now I want to get the a/c-heater box installed, but I need to find a way to adapt the more modern spring lock lines to the older mustang condenser o rings lines. Anyone have any success doing so?
cdog02mustgt
That's what I was thinking of having done, but I thought it would be easier to find an adapter then have the tig welded. I just need to find someone with a tig welder.
cdog02mustgt
The heater core I will be able to fit, its the evaporator that I am needing to adapt. I think I am going to take it to a radiator shop
