My 2v Mod Fox
2vmodfox
Ok so I've always wanted to build one of these. My sn95 ended up having alot more rust on it then expected so plan was to buy a notch and do it. Well a friend of mine built this one and was gonna help me do mine. But times got hard for him so he sold it to me for 4000 witch is a steal for the amount of work done to it
The day I bought it. Was originally a 4 cyl car
But what's done to it so far
Has a 99 pi 2v motor with mach 1 shaker, t45 trans, 8.8 with some jegs axles, tubular k memeber, coilovers on all 4 corners, sn95 interior, and a tune
He took it to the track with radial had a best time of 13.1 not bad for a stock 2v with a tune!
Sent From Your Moms Phone
2vmodfox
So since I'm putting my sn95 back to stock I started swapping everything over
sn95 before :/
Of course first thing I swapped was my wheels lol
After that I swapped my cobra brakes then over my seats tried to swap the fr500 steering wheel but can't get the old one off for the life of me
Before
After
Seats before
And after
Gonna get some covers that match for the rear one day
2vmodfox
Been busy past few days running to junkyards and trying to get my sn back to stock but finally got to finish up the interior on it
Before
After
So differences I installed a black steering column cover fr500 wheel black airbag black gauge cluster bezel black pass air bag black carpet and the black center console from my sn also installed my mgw shifter
2vmodfox
Ordered a bunch of little things for the car
But first thing I got was my headlights I got those installed looks 1000 times better
Before
And after
And a side shot sorry for night pics lol
Also had some extra led bulbs laying around so I installed some for tag lights
2vmodfox
So waiting for parts to come in still rest should be here soon. But got my wiring for my dome light figured out and wired up just need to add some more lights to brighten it up some more
2vmodfox
I also forgot to mention I started my long tube swap but got stopped on the drivers side do to steering shaft. Gonna have to have the back cylinder runner cut and moved over some to fix the problem
You can see here what the steering shaft is doing just chillin on top of the pipe
2vmodfox
Well worked a little on the fox tonight. Replaced all the sunroof weather striping and painted all the metal and replaced the striker bushing on the hatch. Still leaking a tad but will try to figure that out later today
Dropping my long tube off tomorrow to start the process of moving the runner over
2vmodfox
Well it's got the mach 1 scoop on it and it was light silver so I just painted it black for now but I wanna get it molded and makes it look like one. One of these days
hipoman
Would the stock cowl hood or one with a little bit more cowl save u time & money. Just asking. I dont know the difference in the heights
hipoman
Will u go with an all fiberglass hood? Mating metal & fiberglass has its problems over time.allways did like the mach
2vmodfox
Idk well see don't know for sure if I wanna keep the shaker yet It looks cool but causes a bunch more work
