Need help with 96 4v clearance issues in 86’ fox
Discussion in '1979-1993 4.6L Conversion' started by 91bimini_coupe, Jan 25, 2018.
  1. 91bimini_coupe
    91bimini_coupe Member
    5
    1
    13
    been helping a buddy with his 86’ 4v swap and can’t seem to get the motor to drop into the k-member. It’s a Maximum Motorsports modular k-member made for this swap but seems as though the oil pan is hitting the k-member. Do we need to swap oil pans for correct fit up or are we missing something. This is a first time swap for both of us so any info helps. Thanks.
  2. cpearson1342
    282
    64
    58
    Probably an issue with the k-member. I haven't had any issues with stock or upr mod swap k member
  3. Bill
    1,406
    242
    93
    What did the 4V come out of? I was an MM dealer for years and never had a problem with a Kmember. If it is the correct part number, the other possibilities include wrong oil pan or wrong motor mounts.
  4. 91bimini_coupe
    5
    1
    13
    It came out of a 96 cobra. We even called MM to make sure and they said the same thing you did.. so I’m stumped. And the oil pan is the stock one so it should fit fine.
    Bill likes this.
  5. Bill
    1,406
    242
    93
    That is a strange one.
  6. cdog02mustgt
    cdog02mustgt Well-Known Member
    64
    27
    48
    Are you positive the pan is stock? Or did you get a non modular k member?
    Did you end up getting it together?
  7. 91bimini_coupe
    5
    1
    13
    My boy said it’s the right kmember but I’m having second thoughts. We haven’t touched it since I asked just trying to trouble shoot. I’ll keep you posted when we fuck with it
