new w/ 92 vert lx
Discussion in 'Welcome New Members' started by mitch, Apr 12, 2018.
  1. mitch
    mitch Member
    11
    2
    13
    right in the middle of a 2v 4.6 swap into my 92 4cyl lx. 98 npi shortblock with pi heads and intake. 03 crown vic 4r70w and wiring harness and ecm from same 03 p71 hence no pats. using the 98 8.8 with disk and spindles and brakes up front. heres some starting pics, and many more to come
    Bill likes this.
  2. mitch
    mitch Member
    11
    2
    13
    used a 98 gt k member and was able to easily put the fox rack on and the steering shaft and 98 powersteering lines hooked right up. using hydro boost as well. havent gotten the spindles on yet. am i going to run into a problem soon with the fox rack? i dont understand why everyone says you have to use the 4.6 rack.
  3. Bill
    1,399
    240
    93
    You can use the fox rack. The distance between the outer tie rods is one of the deciding factors, but you can mix and match components. I use the newer rack because I like the feel better. I also like the ratios. As far along as it sounds like you are, you'll do fine. I've never used that tranny setup, so I can't help there, but I'm sure you'll figure everything out. I like to use a tubular Kmember, as it gives more wiggle room for shifting the set forward and using bigger headers. Have fun with it and welcome.
