On 3 performance fuel system ebay
88Foxbody
Just found this on eBay looks like a good system for a conversion. Just type in this title on eBay and it will pop up.
Sent from my Nexus 4 using Tapatalk 2
88Foxbody
Well its a system that can be versatile. 2 or 3 pumps can be used. Seems to be everything you need also for a clean factory like install all in one stop shopping.
521 HP here and running a single in tank Aeromotive 340 LPH pump in a return style setup. One pump is good to about 600 HP depending on your setup. YOu can use the rest of the stock setup or go aftermarket. I used the stock line to the front of the car, then adapters to braided lines into the regulator. Out of the regulator i used braided and aeromotive fuel rails.
