T56
Discussion in 'Drivetrain' started by CapriGT, Nov 13, 2017.
  1. CapriGT
    CapriGT Member
    9
    1
    13
    I'm leaning towards going with the 03/04 Cobra engine with T56. Does T56 use a cable operated clutch like the Fox. Which driveshaft do I need? What's the best crossmember option considering my car is 1980 with the narrower mounting points on the body.
  2. Bill
    1,346
    238
    93
    If you don't find a cross member to fit the 80, you might consider changing the mount brackets. As I recall, the early Capri has five (or maybe six) spot welds holding each mount in place.
  3. raysmust
    raysmust New Member
    3
    0
    1
    You will have to move the crossmember brackets on the floor. I would get a Stifflers crossmember as they fit very well.
  4. CapriGT
    CapriGT Member
    9
    1
    13
    Thanks, I checked out Stifflers crossmembers. they look like a quality part.
