Tach wiring and alternator wiring
Discussion in '1979-1993 5.4L Conversion' started by keith robson, Jul 7, 2018.
  1. keith robson
    keith robson New Member
    2
    0
    1
    I am using a 2005 crown Vic 4.6 2v pi and have swapped back to edis 8 does the factory on the 83 Capri able to just plug into the tach output on the edis8 or does I need to step up the voltage signal as it would be on a the OEM Capri coil pack signal. Also the alternator is a three wire. I understand that one goes constant 12v + and one is not needed. But I need to hook up the other one to excite the alternator into charging. I thought I might be able to wiring it to the 12v+ but with a resistor inline. Any help would be great.
  2. keith robson
    2
    0
    1
    I also just realized I put this on the 5.4l section and not the 4.6l whoops
  3. Bill
    1,413
    245
    93
    Welcome to the party. I'm not a wiring guy, but there are plenty of them here, so hopefully someone will be able to answer. In the mean time, make yourself at home.
