Wreckedj30
Sn95 parts
New 4.6l a/c compressor installed never filled with freon or run
24lb blue fuel injectors used set if 8 plus extras that could be rebuilt $35
99+ doch cops I think I have 2 used still with in ohm spec $20
2-4.6l coil packs fit multiple cars/years $20ea
Coil pack valve covers 93-98 4.6l dohc $15
93-96 Lincoln mark intake manifold complete with tb,iacv, fuel rails,port matched imrc and new gasket set $130
1999 continental return less fuel rail no transducer $15
Brand new 99-04 rear disc brake conversion rotors, calipers and brackets $230
96-98 4.6l gt computer $50
Foxbody parts
89 speedo cluster 140mph speedo$45
Complete efi swap from 5.0l or will separate(harness, ecu, upper and lower intake manifold, fuel rails, distributor w/tfi, all sensors, air duct and intake, 19lb injectors $350
Auto and manual 5.0 computer
5.0l blue ford racing hoses $45
5.0l flow tech header with matching xpipe $175
Msd tfi coil $25
Convertible boot cover$15
Convertible rear side window and motors $15 each side
Convertible glass back window $15
Hvac system dash controls and cables $15
More stuff just can't think it's late pm or txt me for prices an pictures
951233825seven
Foxbody parts
Msd tfi coil $25
951233825seven
