03/04 svt cobra built drivetrain complete with extras
playsnake
placed on ebay today item #130320260229 *******$17000 neg.********
2003/2004 svt cobra drivetrain complete with extras, everything you need to drop in and have a killer 500-550 h/p 500-550 tq beast with smooth everyday driveablity and very good gas milage. 95% of everything listed is brand new . It was all installed in my project car but never started. I have been building a 89lx mustang with 03/04 cobra drivetrain the last couple of years, but due to new member of or family and zero time i have decided to sale. What i have is a very over the top set up for any project car. Motor can handle up to 1400h/p. Everything is stored in a climate controlled shop. The motor will come complete all accesories including belts, hoses, t-stat housing. With t56 transmission installed with vacuum harness and engine harness. The engine harness is the detail zone set up, it is a stand alone harness that just runs the motor / fuel / emissions and transmission. It uses the factory computer with the pats system turned off and is fully programmable just like a stock 03/04 car. The coil covers / hydroboost / blower and plenum have all been painted with high temp semi gloss black. Buyer is responsable for shipping i will help prepare for shipping and will also look at delivering within reasonable distance (300 miles max) ( if paypal is used buyer must pay paypal fee ) i have listed all of the items in this set up. Prices do not include shipping cost. As you can see i have well over $30000 invested, i realize when building a project car you lose money unless its a classic so i am negotiable but i do not have to sale! ( everything is paid for and not eating anything and sits just fine in the shop so please before you make an offer really look at what you are buying)
******just for some extra info replacing the blower on this set up with a aftermarket blower can add another 100 to 200 h/p and tq****** my email is tycoyarb@comsouth.net
i started with a brand new oem 2003 ford svt cobra crate motor complete $11500
then completely disassembled and had reassembled by ( proline racing with the following upgrades. All accesories were reused including cobra crank
proline racing assembly cost $1000
teskid aluminum block $400 (used)
bore/hone w/ torque plate $310
machine block deck surface $150
align hone block w/5 mains $175
jet clean block $50.00
(8) pin fit pistons 64.00
(8) pin fit rods $64.00
balance crankshaft-internal $150.00 (reused from crate motor)
manley rods (reused from new crate motor)
manley 3.572 forged pistons w/ coated skirts -11cc dish $599.99
(2) arp 2000 3/8 rod bolts for manley rods set of (8) $128.78
2005 ford updated heads $1800 (better cooling flow for rear cylinders)
clevite sbf main bearing $79
clevite rod bearing $79.00
ford mustang roller pilot bearing $30
rings total seal stainless $199
compression ratio 9.64:1
stage 5 stiegemeier port with new welded dragon tb/pl $1370
2.76 upper pulley $85
2 pound lower metco pulley $100
arp head stud kit $209.39
arp cam bolt (4) $101.56
melling select oil pump with billet gears $279.69
arp 4v main stud w/ windage $199.00
pro line racing oil pan stud kit $25.99
motorsport front seal $11.18
motorsport rear main seal $19.67
motorsports cobra timing cover gasket $25.59
fel pro modular 4.6 head gasket (2) $99.90
innovators west std 6 rib damper with metco adapter $575
(2) 100mm metco idlers (3) metco 90mm pulleys /adjustable idler plate $580
jlt intake tube/ s&m 10†filter $150
sct 2800 air meter $225
03/04 cobra stock headers (reused from new crate motor)
(used) magnaflow tru-x pipe with high flow cats $350 ($550 new)
complete high performance catch can set up installed with check valve and stainless braided hose. $300
set of powered by ford coil covers $99.00
*********engine harness and computer************
detail zone telorvek mk-97a harness $850
ecm reprogram for (pats) removal $350
oem 2003-2004 ford svt cobra ecm computer $300
*******transmission************
03/04 t56 with 4340 forged steel tob retainer sleeve $2300
aluminum centerforce flywheel $750
centerforce clutch $220
centerforce pressure plate $385
ford h/d throwout bearing $20
oem clutch fork $35
atlanta driveline aluminum drive shaft all heavy duty parts $450
**********fuel system************
(used) 03-04 cobra rear tank $300
(used) vent canister and emission control
fore precision dual fuel hat $420
(2) ford gt super car fuel pumps $230
lethal performance dual fpdm wire harness kit $389
10 micron reusable fuel filter $89
-8 braided stainless teflon hose with pressed fittings $300
-10 braided aqp vent hose $100
lethal performance sieman deka 63 pound injectors $400
*********cooling***********
lfp extreme intercooler heat exchanger (input and output was moved and rewelded) $320
lfp gen (11) cooling mod $118 added different fittings and stainless braided hose $70
sean hyland high output water pump $164.95
bosch intercooler pump $185 comes with -12 aqp stainless hose $50
03/04 cobra radiator $200 with special 180 t-stat $60
(used) 03/04 factory cooling fan
03/04 cobra a/c condensor $185
**********brake system***********
hydratech hydroboost system $595
cobra (r) master cylinder $150
(used) 03/04 factory brake fluid cooler
stainless braided teflon hoses with pressed fittings $200
