Has anyone else had a problem with a rattling noise coming from the engine? We were pretty sure we didn't hear it before we took it out, but once it was in the fox we started hearing it. I have an o/r x-pipe that currently has an exhaust leak on the driver's side. I've heard anything from head tick to problems with pistons, or the timing chain tensioners which apparently make that noise when they go bad. Hopefully someone else has resolved this issue and can help me out. I can put up a video of it if needed, but it usually happens closer to 3000 rpm or when I push the gas pedal about half way down and it less noticeable if at all at idle.
In other news, I finally got my dash back in and the majority of the wiring in so that all the lights and such minus the reverse lights and alarm system, etc. It was finally worth all the hard work and I'll be taking it on it's first real drive to school tomorrow, so hopefully all goes well.
