Are there any steering shaft issues? With the 4v
8t9notch
Im in the process of installing a 94 4.6 dohc into my 89 notch, and i was wondering if there was any issues with the steering shaft hitting anything? I would appreciate if someone chimed in thanks...
SVTCAPRI
[quote author=8t9notch link=topic=398.msg903#msg903 date=1269321925]
[/quote]
As long as you use stock manifold you should be fine. Headers may need slight mods- ditch the rag joints for universal style anyways. Now I have major issues with mine cause I did the 04 dash trans plant. Didnt get it all figured out yet! Good luck!
8t9notch
thanks for the input, It will probably save me a lot of hassle. Your interior looks good, Keep up the good work. Bet yours is quick when its done. I always liked the capris. Thanks
We had a hell of an issue so we went with a flaming river and a couple of knuckles:) to make it work..
