Lakewood # 15230 Blow-proof Bellhousing for 1996-2003 Ford 4.6l & 5.4l V8's to Tremec TKO & Tremec TR3550 Transmissions with 7.20" Input Shaft.
Part Number LAK-15230
UPC 08404115230
SFI-Approved Yes but out of date
Block Plate Included Yes
Bellhousing Bore Diameter (in) 4.850 in.
Bellhousing Depth (in) 6.924 in.
Bellhousing Type New
Clutch Fork Included No
Adjustable Fork Pivot Recommended Yes
Bellhousing Material Steel
Bellhousing Finish Red enamel
Quantity Sold individually.
Notes Designed for 1996-2003 Ford 4.6L and 5.4L using Tremec TR3550 or TKO. Will also fit Jerico DR-4 with proper input shaft.
Ever wonder how the SFI tests bellhousings like these Lakewood safety bellhousings? First, they bolt the bellhousing to a machine with a cast iron flywheel and saw inside it. Then they spin the flywheel, causing the saw to cut through it until it explodes. If the bellhousing can contain the explosion, the bellhousing is approved. These safety bellhousings are a safeguard to minimize the destructive effects of such an explosion. Don't take unnecessary chances with your safety and the safety of innocent bystanders--Lakewood not only provides top-notch products, they also provide peace of mind.
