So, there are a number of ways to get more negative camber, but this is one of those off-label uses. The Steeda three-bolt cc plates can be installed on the wrong sides (left on right). This allows the slots to go side to side instead of front to back. In doing so, you give up some ability to add positive caster. Most of the time you will be stuck with around 3.5 degrees. However, with some very minor dremel work, you can get 4.5+ degrees of negative camber (4+ degrees with no work at all). It is a low budget solution to something racers spend big money on. It will also freak out your alignment guy.
