hydroboost install
hcantu83
I have a 92 stang and I'm planning on coverting to 5 lug discs brakes, but instead of running a larger brake booster I want to swap to hydroboost. how hard is it to swap? will the hydroboost lines bolt to the 5.0 power steering pump with no modification?
any help will be greatly appreciated...
Hector
I have not checked to see if fittings will connect. Worse case you will need an adapter fitting at most. Or run custom cut to length lines and get what ever fitting you need. I know some oreilly autopart store cut to length lines with fitting on each end pretty cheap.
