Project 1Badfox
Shane93
Okay , I have 93 black coupe car that has been a 6.50 quick street drag car for the last 6 years. The car has a full 14 pt cage . I will be cutting out main hoop and dash bars , i will be leaving all rear bars and subframe bars. I picked this car from a buddy of mine on trade .The goal is to make a 550 -650 hp street car . The engine and tranny from 03 cobra with 46k . With future plans to upgrade to a Kenne bell . I will be smoothing engine bay and re painting . I will be using a complete cobra harness front to back. The black/ grey dash and interior will be used also. I need new seats though, prob go with Corbeau gts2 black suede seats. The. Tranny will be sent off for stage 2 upgrade . The spool and axles will also need replaced. I also have cobra front spindles and brakes, that will need to be installed . The front core support will need replaced also. Well a lot to do but that's the plan !
That sounds like a great plan. Are you going to use Foxrod panels to smooth the engine bay? If you have to replace the front core support anyway, that might save you some time and a lot of work.
I typed Foxrod but meant Scott Rod Fabrications. I've seen a bunch of the pop rivet aluminum kind at shows and thought they look cheap, but I really like the weld in contoured setup.
They will be weld in style. The core support will be custom made piece for cobra radiator and heat exchanger.
image.jpg image.jpg image.jpg Alittle more done removed core support and welded in scotrod panels, will be removing sway bar supports next.
My front bumper cover is toast also . I didn't realize it was in that bad of shape cracking and basically POS . What do you guys think was looking at cervinis stalker or Saleen style lower valance.
image.jpg Modified the cobra pedal assemble to the fox steering column, cut welded and braced painted gloss black. Also made blank off plate for rear truck area that use to house 5 gallon sumped fuel cell.image.jpg image.jpg
image.jpg image.jpg image.jpg image.jpg We'll got a little more done today! Installed Fatmat thru the car front to back. Removed old brittle sound deadner first PITA!!!
