Harness will swap a 1999-2004 Mustang 4.6L into any vehicle.
Setup for DOHC, but SOHC and 03-04 supercharged Cobra are possible with minor adjustments.
4R70W automatic transmissions option available!
Easy 4 wire hookup (battery positive, ground, keyed run, and E-fan).
EEC-V computer will need to be reprogrammed to disable PATS anti-theft system and other emissions system not used.
Stock returnless fuel system or aftermarket return fuel system.
Coil on Plug Ignition system.
EV6 injector standard, EV1 will be available by request.
EGR system included, other emissions not included.
70amp Fan relay included.
Comes with an assortment of wire loom, harness wrap, and zip ties to give it a finished look!
CLICK HERE FOR MORE INFO
