swaybar problem on 03 cobra motor into fox???
JRAYMOND
hey guys looking for some help i had to cut my swaybar brackets for room for the 03 cobra engine any solutions on running a swaybar without going with a whole new suspension setup?? i'm running a racecraft k member with stock lower a-arms(to reduce my costs for now) and coilover shocks any info would be great. thanks john
SVTCAPRI
I had the same problem. My alternator and a/c pump resting on brackets. I cut mine out too. You can upgrade to a 94 or 95 sway bar. They are mounted on the frame rail instead of on brackets like the foxes. I havent done mine yet but plan to. And I read that you need to have the 94 sway bars bent in about an inch on each side to fit right.
