Hey guys, good to be here.
Im swapping a 4V/Whipple 2.9 into my 93 Lincoln Town Car.
Im using a Marauder harness, OBD2 and plan on using a Tablet with Wireless dashboard software for the gauges.
Essentially, I just need the engine to start and operate the fan. The rest of the car will retain the factory wiring.
I have removed the OBD2 wiring from a Marauder dash harness.
Here are my questions:
-How and where do I incorporate the PCM diode?
-What wires need to be HOT so the car will start using the Factory ignition switch?
(I have SCT software to turn PATS off)
-The OBD2 port has wiring for an ISO bus (what the hell is that and what does it get hooked up to?)
-The SCP Bus goes to various sensors....can I just hook the wires to the appropriate PCM inputs and be ok?
Ive attached a few pics, as well as the Marauder pcm pinout
