Sub0ca
Perfect I'll giver a try thank you for the help was worried about chopping up sway bar mounts. Doesn't appear to be much room for connecting the brake Lines after thou
I have a swap in progress...
I'll put more up when I get further along...
How heavy is the 5.4 DOHC as compared to a 351 Windsor? The 5.4 DOHC has Aluminum heads at least. I guess I never consider the modular motor to be too heavy.Agreed. The biggest issue I have with the 5.4 for most swaps is they make the fox nose heavy
Yes it fits but she is tight. I'm using factory headers with Mach x pipe modded to work with my set up
No direct fit, slotted holes a bit
I'll try to get a better picLooked like the reservoir isn't as offset as mine
