Ford 5.4L Fox Swap
I have searched but still have questions:
What long tubes will fit? What short tubes will fit?
Will the stock 93 Cobra brake booster fit?
Will hydroboost fit?
Should I remove the sway bar mounts?
Any help here will help me out.
Welcome to the site. There are a lot of threads on here that will have bits and pieces of what you're looking for. The 5.4 is tight no matter how you do it, but it will fit. The 93 booster will not fit with a mod motor. Also, the 93 booster is vacuum assit. The 5.4 won't make enough vacuum to pull it. The hydroboost will fit, but it is really tight and will require some added space somewhere. Where you put it depends on what you plan to do with the car and what your budget is.
