Headers to fit 03 cobra engine and 4r70
Any advice on what headers to use that will fit? Swapping from a 2v to the 03 setup in a 90 GT. Has a 4r70 and 03 mounts. Team z swap k member also. Thanks.
my bet is that the 03 Mach 1 headers would work, but you could try calling JBA. They would probably be good help.
Understood. I have no experience with Kooks. We were JBA, SLP and Mac dealers when I was in the business. I have installed BBKs, but was not a dealer. Kooks should have a help desk/tech line you can discuss the build with. I do recommend the ceramic coating. Regardless of the build, heat will be a factor under the hood.
