4.6lsleeper
Whats up, name is isael im in north florida (jacksonville) got a few toys but the main one is under the knife at the moment, shold be back up on the road by this weekend after a complete overhaul... Here is a specs on it
1990 mustang coupe
Modular swap (of course)
Teksid block
.20 over manley pistons
Manley rods
Arp2000 upgrade everywhere
Forged crank
Mmr bigger oil pump available
New timing assembly
Moroso oil pan
Heads
Mild port work
Custom grid cams
Full crower valvetrain
Arp headstuds
Heavy duty double valvesprings
Etc
Full e85 fuel setup
Big rails
96lb injectors
Decent size feed/return lines
Fuel cell in the trunk
Aeromotive regulator
Etc
Tranny
Pa supercomp c4
Alan pope custom converter
Aluminum driveshaft
Built rear end
Power adder
Whipple
A box full of pulley
And a small shot if needed
And a few other stuff such as adj suspension, tubular front end, mafia, welded subframe connectors, etc etc etc....
1990 mustang coupe
Teksid block
Manley rods
Forged crank
New timing assembly
Moroso oil pan
Heads
Mild port work
Custom grid cams
Arp headstuds
Etc
Full e85 fuel setup
Big rails
96lb injectors
Etc
Tranny
Pa supercomp c4
Aluminum driveshaft
Built rear end
Power adder
Whipple
