vettn71
So, after a hiatus of three months I'm healed up enough to do a bit of work I dumped my MIG flux welder to get an Eastwood 135 MIG welder with shielding gas and the stud welder attachment, as well as the spot welder attachment. We'll see how that goes. I did have a chance to use the new welder to repair the radiator support frame. It had been pretty crunched up, both by someone using it to tow with and the bottom was crushed. My friend came over to help and we cut the bottom off the old radiator frame, measured the new (93) radiator frame and cut it a bit oversize. As everyone probably knows, the 87 to 93 radiator frames use a different support for the collapsible bumper supports. The general frame is the same, so cutting the bottom off a later model frame and welding it onto the existing frame is the best option (at least for me).
I measured from the inside of the top of the new frame to the bottom of the new frame to get that dimension, as the old frame was too deformed to trust anything from it. After squaring things up and cutting off the excess, the lower portion was tack-welded onto the upper portion.
I really thought this was going to be much more difficult, but it actually was pretty easy. Measure twice, cut once type of thing. The upper portion on the driver's side was so deformed I will have to tap it back in to line up with the new lower part. The ratchet strap is being used to keep the sides of the frames in the proper relationship, as everything is used to support everything else, if you get what I mean. Cut one part loose and things start flopping around. I will weld plates over the butt welds to strengthen the assembly before I take the strap off.
I hope this helps anyone wondering what to do about their beat up radiator support frame. The replacement sold by various parts places don't have the primary side and would be a bunch of extra work to fit.
Jim
Jim
