Cluster options
Vnmous1
I want to keep the stock dashboard from the coupe...what are my options for clusters when swapping the 03-04 cobra motor?
im not sure but pretty sure, you may be able to splice but not sure there will be more people that will post other than me, im keeping my old cluster but i wont have a speedo, i am also running a distributor and factory 5.0 harness on a 4V
Vnmous1
Oh ok well I will definitely post what I do one way or another if I figure it out
Sent from my SPH-D710 using Tapatalk 2
Are you using the T-56? You can use you're factory cluster. Obviously if you do, you'll have to run an aftermarket boost gauge. You just have to find the adaptor to run the speedometer cable for your factory cluster.
I am in the midst of a b-head 4.6 swap and plan on using the factory cluster with my T-45. I plan on upgrading to a T-56 next year.
Interior wise, I don't want any indication that I have a 4.6 under the hood.
Vnmous1
I'm going using a C4 and likewise not putting anything out of the cobra as I am still using and plus I don't want anyone knowing I have my cobra motor now in my coupe
I used a cable X to convert the digital VSS signal to a mechanical output and a for the tach I used an autometer tach adapter.
VNMSGT
Is there a thread anywhere that shows how to install a 96-98 Cobra or GT cluster into a fox?
