Progress on my Zephyr
massacre
Hello,
I finally had some time over the past few weeks to get my engine and trans out of the old project, to my house 20 miles away, and then onto a dolly and under the new project and installed.
I have been making progress on the car, but mostly just getting everything in working order like lights, wipers, blinkers, horn, etc.
Since I finally got the mill in, figured I’d post it here. Now it is a modular fox hahahaha
massacre
So what gives with this website? 20 views of my thread and not 1 like, not 1 comment?
Seems weird
Dude, that is an awesome project. I promise I'm watching :)
massacre
I was able to modify my gas filler tube last week.
I bought a 1986 LTD wagon gas tank, because I am going with fuel injection.
I was able to locate the proper fuel pump hanger for this tank, but the fuel pump was very small.
Was able to modify the supply tube to fit my 255lph pump. The hanger takes the same electrical harness connector, so that is a plus.
The 2-1/4” stock gas filler tube does not fit the new tank. New tank is 2” so went with a later fox filler tube.
Problem is- the stock filler tube mounts with 4 bolts, the new tube mounts with 3 bolt flange.
Ended up cutting out a flange from steel plate, welding that to the stock flange, and redrilling the 4 holes.
It took longer than I thought to get it right.
Came out OK sorry for the crappy pic.
I have decided to convert to COP ignition. There just isn’t enough room to mount the coil packs in a way that I like.
Ended up pulling the motor to swap the COP valve covers.
One of my valve covers was broken so I welded it up.
Before
After
It is not perfect but it will work lmao.
Waiting on valve cover gaskets and fuel rails and regulator.
Was going to run a stock-style fuel rail but it is really tight to the firewall.
I wasn't able to see any of the pictures. What size tank did the LTD Wagon come with? I've got one on my project list that will be a cruiser for road trips. I'm considering doing the T-bird tank for a bigger volume, but haven't done all the research yet and have only seen it done a couple of times.
massacre
The pictures are hosted from an image hosting site that works on every other site.
Not sure what is going on there. I can see them fine
massacre
Thanks!
Was originally a 6 cyl automatic, but I bought it as a roller. Had no engine, no trans and no driveshaft.
I was able to complete the COP conversion wiring, used a Markviii COP engine harness from the junkyard, plus a 2v COP swap harness I bought by mistake. Took a little while to get it right but I’m happy with that.
Also got a new head cooling mod, made by Wonder Racing. What a great product!
I was using Markviii heater core supply and return pipes, but they are too tall. This new kit puts the supply much lower, I’m going to have to shorten and weld the return pipe to match. I need to keep the heater core for defroster.
Got the new fuel rails installed, and have the fittings to route everything. Have to make a bracket for the regulator still.
Gonna do the final install on the cooling mod today, and start reworking the return tube. Then wrap the engine harness and reinstall the engine hopefully this weekend.
