Those springs are beefy and the rods are absolutely beautiful. You will love the MM front end. We were a MM dealer/installer for years and swear by them. It will give you steering geometry control that is hard to beat and is durable enough for daily driver use. If you haven't looked at chassis stiffening products yet, Brian Figg at Stifflers makes about the best subframe triangulation system on the market. Even if you already have subframe connectors, his stuff can be adapted to almost any brand connector.
