84 Capri another mod swap
Capri_gt
Well thats was something I didnt have any clue about. Wiki really does have everything doesnt it?
Capri_gt
Well an update about the capri lol. Im waiting on taxes so I can get another new clutch cable. Got one in a kit with the adjusters and it is trash, adjust it hit the clutch and the cable stretches noticably. Everytime. I alsoneed to get new rear brake lines ( there cracked up ) and the fuel pump and sending unit I need and she should be on the road after that. Im going to be making my own interior panels and dash for her as well. The 97 I put in is just to get it home. Im modifying the body to much to use the stock interior panels and I honestly dont like the dash set up at all so im going to make my own.
Capri_gt
Ok so, looks like my fuel pump is fine. I guess I jumped the gun on assuming it was bad. So now ive got a problem because I cant figure out why it wont turn on with the key. Any ideas. All new fuses. So its not that. Ive gone through and checked all the wiring. But I cant seem to figure it out.
Capri_gt
Could it be the pats if everything came from the same car? All the wiring, keys, computer, even the drivetrain.
I have heard of guys letting their cars set for a period of time and it goes in to freak out theft mode. You running the sn95 dash
Capri_gt
Starter turns over great. No clicking from it. Just no fuel pressure at all. The dash will beep like three or for times. Im not sure of the theft light.
So starter cranks motor, fuel pump primes, but no pressure at fuel rails, does the car start and die after a few moments.
Mine done the same thing i had to get a chip to disable pats and then i had pump prime and car started, then i fried the ECU lol. Might check the inertia switch buy the taillight, thats cuts fuel off, little box with red button on it push the button down if its poped up.
